Salta al contenuto principale
Asus Zenbook UX550GE-XB71T Battery Replacement
Cosa ti serve
  1. Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn computer off and disconnect it from power.
    • Flip it over so the backside is facing you.
  2. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 2, immagine 1 di 2 Asus Zenbook UX550GE-XB71T Battery Replacement: passo 2, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove the ten screws under the computer.
    • Gently remove the back cover from the device.
  3. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 3, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the four screws along the battery.
  4. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 4, immagine 1 di 3 Asus Zenbook UX550GE-XB71T Battery Replacement: passo 4, immagine 2 di 3 Asus Zenbook UX550GE-XB71T Battery Replacement: passo 4, immagine 3 di 3
    • Disconnect the ribbon cable by pushing upwards on the ZIF connector.
  5. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect and remove the battery from the device.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,062
