Salta al contenuto principale
Asus Zenbook UX32VD HD Web Camera Replacement
Cosa ti serve
    1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: passo 1, immagine 1 di 1
      • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
      • Use low heat with the heat gun. Over heating could damage delicate electronic components.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 2, immagine 1 di 3 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 2, immagine 2 di 3 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 2, immagine 3 di 3
      • Insert a spudger between the display screen frame and the back screen panel.
      • Pry the display screen frame away from the back screen panel.
      • Continue to heat and remove the display screen frame along the whole perimeter.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 3, immagine 1 di 3 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 3, immagine 2 di 3 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 3, immagine 3 di 3
      • Remove display screen frame completely before adhesive cools and hardens.
      Chiedi a FixBot
      Aggiungi Commento
    4. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 4, immagine 1 di 2 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 4, immagine 2 di 2
      • Unplug the bundled cable connector.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Chiedi a FixBot
      Aggiungi Commento
    5. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 5, immagine 1 di 3 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 5, immagine 2 di 3 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 5, immagine 3 di 3
      • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
      • Remove the camera completely.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membro di CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Membri
24 guide realizzate
2Commenti sulla guida
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - Rispondi Condividi
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 32
Tutti i Tempi: 2,392
