Salta al contenuto principale
Asus ZenWatch 2 Battery Replacement
Cosa ti serve
    1. Asus ZenWatch 2 Battery Replacement, Battery: passo 1, immagine 1 di 3 Asus ZenWatch 2 Battery Replacement, Battery: passo 1, immagine 2 di 3 Asus ZenWatch 2 Battery Replacement, Battery: passo 1, immagine 3 di 3
      • Remove the four 3.5mm screws to detach the case using the T5 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus ZenWatch 2 Battery Replacement: passo 2, immagine 1 di 2 Asus ZenWatch 2 Battery Replacement: passo 2, immagine 2 di 2
      • Slide the spudger under the battery and lift to remove.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 16 persone hanno completato questa guida.
Moriah
Membro da: 02/20/17
811 Reputazione
3 guide realizzate
USF Tampa, Team S1-G1, Leahy Spring 2017 Membro di USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Membri
10 guide realizzate
13Commenti sulla guida
Where do you get the battery?
Mark Miser - Rispondi Condividi
Sir,
I own Zenwatch 2 and it is just 14 months old. I left it uncharged for months. Now it is not at all charging. In Service Centre, they said Asus did not send any replacement spares even to test what was wrong.
I am from Mumbai, India. Where can i purchase replacement Battery so that i can try? Please help me sir.
Vijaykumar S
Mumbai
vijai kumar - Rispondi Condividi
Only one place I know of to find them: http://www.asusparts.eu/Asus-0B200-01630...
Terrance - Rispondi Condividi
Hello I have ZenWatch 2 Battery WI502Q-SL-BD need help looking Replacement Battery
Angel Alfredo Grant - Rispondi Condividi
i used non original battery, link here. Compare here.
4spam - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 16
Ultimi 30 giorni: 58
Tutti i Tempi: 18,893
