Salta al contenuto principale
Asus X751L Wireless Card Replacement
Cosa ti serve
  1. Asus X751L Wireless Card Replacement, Keyboard: passo 1, immagine 1 di 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus X751L Wireless Card Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus X751L Wireless Card Replacement: passo 3, immagine 1 di 3 Asus X751L Wireless Card Replacement: passo 3, immagine 2 di 3 Asus X751L Wireless Card Replacement: passo 3, immagine 3 di 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
    Chiedi a FixBot
    Aggiungi Commento
  4. Asus X751L Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Asus X751L Wireless Card Replacement: passo 5, immagine 1 di 1
    • Using your fingers, lightly lift up on the black and white antenna cords.
    Chiedi a FixBot
    Aggiungi Commento
  6. Asus X751L Wireless Card Replacement: passo 6, immagine 1 di 1
    • With your fingers lightly pull the wireless card out of the slot.
    • Make sure to keep the card parallel with the motherboard when removing from the slot.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Matthew Martin
Membro da: 02/02/17
217 Reputazione
Una guida realizzata
USF Tampa, Team 17-2, Blackwell Spring 2017 Membro di USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Membri
5 guide realizzate
1Commento della guida
I feel the existing WiFi card is not very good. Is there is better one I can get for the Asus X751L?
July 3, 2023.
cookbake2 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 11
Ultimi 30 giorni: 39
Tutti i Tempi: 2,791
