Salta al contenuto principale
Asus X751L Keyboard Replacement
Cosa ti serve
  1. Asus X751L Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus X751L Keyboard Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus X751L Keyboard Replacement: passo 3, immagine 1 di 3 Asus X751L Keyboard Replacement: passo 3, immagine 2 di 3 Asus X751L Keyboard Replacement: passo 3, immagine 3 di 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 17-2, Blackwell Spring 2017 Membro di USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Membri
5 guide realizzate
1Commento della guida
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
phil.kath4 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 25
Tutti i Tempi: 3,733
