Salta al contenuto principale
Asus X55C CPU Intel Replacement
Cosa ti serve
Panoramica video
  1. Asus X55C CPU Intel Replacement, Keyboard: passo 1, immagine 1 di 1
    • Switch off the laptop and remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus X55C CPU Intel Replacement: passo 2, immagine 1 di 3 Asus X55C CPU Intel Replacement: passo 2, immagine 2 di 3 Asus X55C CPU Intel Replacement: passo 2, immagine 3 di 3
    • The Keyboard is held by 5x locking clips.
    • Pick up a little the one side of the Keyboard and start opening the clips one by one.
    • Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • Please SUBSCRIBE to my channel ツ
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus X55C CPU Intel Replacement, Motherboard: passo 3, immagine 1 di 2 Asus X55C CPU Intel Replacement, Motherboard: passo 3, immagine 2 di 2
    • Remove 3x Philips screws.
    • Disconnect the two small flex cables:
    • Power On button flex cable
    • Touch pad flex cable
    Chiedi a FixBot
    Aggiungi Commento
  4. Asus X55C CPU Intel Replacement: passo 4, immagine 1 di 3 Asus X55C CPU Intel Replacement: passo 4, immagine 2 di 3 Asus X55C CPU Intel Replacement: passo 4, immagine 3 di 3
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Asus X55C CPU Intel Replacement: passo 5, immagine 1 di 2 Asus X55C CPU Intel Replacement: passo 5, immagine 2 di 2
    • Disconnect the two coaxial antenna cables from the Wi-Fi card.
    • Remove any Memory or Dummy card.
    Chiedi a FixBot
    Aggiungi Commento
  6. Asus X55C CPU Intel Replacement: passo 6, immagine 1 di 3 Asus X55C CPU Intel Replacement: passo 6, immagine 2 di 3 Asus X55C CPU Intel Replacement: passo 6, immagine 3 di 3
    • The bottom cover is held by 10x Phillips screws. Remove them.
    • With a plastic tool separate the Upper cover and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  7. Asus X55C CPU Intel Replacement: passo 7, immagine 1 di 3 Asus X55C CPU Intel Replacement: passo 7, immagine 2 di 3 Asus X55C CPU Intel Replacement: passo 7, immagine 3 di 3
    • Disconnect:
    • The Microphone cable
    • The LCD Display flex cable
    • Remove 3x Pillips screws.
    • Lift the board first from the right edge.
    • There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
    Chiedi a FixBot
    Aggiungi Commento
  8. Asus X55C CPU Intel Replacement: passo 8, immagine 1 di 2 Asus X55C CPU Intel Replacement: passo 8, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  9. Asus X55C CPU Intel Replacement, CPU Intel: passo 9, immagine 1 di 3 Asus X55C CPU Intel Replacement, CPU Intel: passo 9, immagine 2 di 3 Asus X55C CPU Intel Replacement, CPU Intel: passo 9, immagine 3 di 3
    • Disconnect the Fan cable from the Motherboard.
    • Remove the screws (4x Phillips screws) that hold the cooling system to the Motherboard
    • Remove the Cooling System.
    Chiedi a FixBot
    Aggiungi Commento
  10. Asus X55C CPU Intel Replacement: passo 10, immagine 1 di 3 Asus X55C CPU Intel Replacement: passo 10, immagine 2 di 3 Asus X55C CPU Intel Replacement: passo 10, immagine 3 di 3
    • Counter clockwise release the screw securing the CPU using a flat head screwdriver.
    • Guideline, lift with equal pressure on two sides of the processor chip to avoid bending any of the pins.
    • Intel Core i3-2370M
    • Before installing the new CPU, clean the Cooling system and put new thermal compound / paste.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
197.270 Reputazione
330 guide realizzate
Master Techs Membro di Master Techs
Community
334 Membri
1.694 guide realizzate
5Commenti sulla guida
In step 3 my computer had an extra screw for the DVD drive. So make sure your not trying to pry it open with the screw in like i did.
bill cool - Rispondi Condividi
Hi there!… I have an old Asus X550CL laptop with an I3 processor. So you know if it’s upgradeable to an I7?
Best Regards!
angelo.cesar79 - Rispondi Condividi
I’ve the same laptop. Were you able to upgrade it?
Manish - Rispondi Condividi
Hi, someone let me know if I can upgrade a Asus X55VD's processor from B980 to i7 2670QM.
Or what to take into account? Power usage? Should I only get an i5?
Thanks in advance
Robert Indries - Rispondi Condividi
Hi there what about the shutdown every 30min exactly
SAINTE-COLOMBE Vonjy - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 36
Tutti i Tempi: 6,604
