Salta al contenuto principale
Asus X551CA Fan Replacement
Cosa ti serve
    1. Asus X551CA Fan Replacement, Keyboard Plate Cover: passo 1, immagine 1 di 1
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus X551CA Fan Replacement: passo 2, immagine 1 di 1
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus X551CA Fan Replacement: passo 3, immagine 1 di 1
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      Chiedi a FixBot
      Aggiungi Commento
    4. Asus X551CA Fan Replacement: passo 4, immagine 1 di 3 Asus X551CA Fan Replacement: passo 4, immagine 2 di 3 Asus X551CA Fan Replacement: passo 4, immagine 3 di 3
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      Chiedi a FixBot
      Aggiungi Commento
    5. Asus X551CA Fan Replacement: passo 5, immagine 1 di 1
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      Chiedi a FixBot
      Aggiungi Commento
    1. Asus X551CA Fan Replacement, Hard Drive: passo 6, immagine 1 di 1
      • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus X551CA Fan Replacement: passo 7, immagine 1 di 1
      • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus X551CA Fan Replacement: passo 8, immagine 1 di 1
      • Once it is free, remove the hard drive from its internal cavity.
      Chiedi a FixBot
      Aggiungi Commento
    1. Asus X551CA Fan Replacement, Spacer: passo 9, immagine 1 di 1
      • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus X551CA Fan Replacement: passo 10, immagine 1 di 1
      • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    1. Asus X551CA Fan Replacement, WiFi Card: passo 11, immagine 1 di 1
      • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus X551CA Fan Replacement: passo 12, immagine 1 di 1
      • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus X551CA Fan Replacement: passo 13, immagine 1 di 1
      • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
      Chiedi a FixBot
      Aggiungi Commento
    1. Asus X551CA Fan Replacement, Battery: passo 14, immagine 1 di 1
      • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
      Chiedi a FixBot
      Aggiungi Commento
    1. Asus X551CA Fan Replacement, Motherboard: passo 15, immagine 1 di 1
      • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus X551CA Fan Replacement: passo 16, immagine 1 di 2 Asus X551CA Fan Replacement: passo 16, immagine 2 di 2
      • Now, locate the two wires connected to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus X551CA Fan Replacement: passo 17, immagine 1 di 2 Asus X551CA Fan Replacement: passo 17, immagine 2 di 2
      • Remove the wires by easily pulling them parallel to the motherboard's surface.
      • The wires are very fragile. Be sure to pull carefully so that they do not break!
      Chiedi a FixBot
      Aggiungi Commento
    4. Asus X551CA Fan Replacement: passo 18, immagine 1 di 2 Asus X551CA Fan Replacement: passo 18, immagine 2 di 2
      • Remove the LCD display connection by gently pulling on the attached wire.
      • Gently lift any tape that may be holding the connection.
      Chiedi a FixBot
      Aggiungi Commento
    5. Asus X551CA Fan Replacement: passo 19, immagine 1 di 1
      • Remove the motherboard from the case by gently lifting it upward.
      Chiedi a FixBot
      Aggiungi Commento
    1. Asus X551CA Fan Replacement, Fan: passo 20, immagine 1 di 1
      • Once the mother board is removed, locate the fan.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus X551CA Fan Replacement: passo 21, immagine 1 di 1
      • Using the Phillips #0 screwdriver, remove the 5.5 mm Phillips #0 screw holding the fan in place.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus X551CA Fan Replacement: passo 22, immagine 1 di 1
      • Lift the fan out of the laptop.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Josh
Membro da: 04/10/14
2.970 Reputazione
12 guide realizzate
Cal Poly, Team 7-22, Regan Spring 2014 Membro di Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Membri
85 guide realizzate
1Commento della guida
Upgrade the memory while you have the motherboard out. 8GB PC3L-12800 SODIMM
iceman - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 28
Tutti i Tempi: 6,218
