Salta al contenuto principale
Asus X200MA Fan Replacement
Cosa ti serve
  1. Asus X200MA Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus X200MA Fan Replacement: passo 2, immagine 1 di 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus X200MA Fan Replacement: passo 3, immagine 1 di 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
    Chiedi a FixBot
    Aggiungi Commento
  4. Asus X200MA Fan Replacement, Battery: passo 4, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  5. Asus X200MA Fan Replacement: passo 5, immagine 1 di 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
    Chiedi a FixBot
    Aggiungi Commento
  6. Asus X200MA Fan Replacement: passo 6, immagine 1 di 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
    Chiedi a FixBot
    Aggiungi Commento
  7. Asus X200MA Fan Replacement: passo 7, immagine 1 di 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
    Chiedi a FixBot
    Aggiungi Commento
  8. Asus X200MA Fan Replacement: passo 8, immagine 1 di 1
    • Slide the battery up and out.
    Chiedi a FixBot
    Aggiungi Commento
  9. Asus X200MA Fan Replacement, Fan: passo 9, immagine 1 di 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  10. Asus X200MA Fan Replacement: passo 10, immagine 1 di 2 Asus X200MA Fan Replacement: passo 10, immagine 2 di 2
    • Unplug the set of wires located at bottom corner on fan.
    Chiedi a FixBot
    Aggiungi Commento
  11. Asus X200MA Fan Replacement: passo 11, immagine 1 di 2 Asus X200MA Fan Replacement: passo 11, immagine 2 di 2
    • Lift up and out to completely the remove fan component.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 21-24, Maness Winter 2015 Membro di Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 24
Tutti i Tempi: 2,705
