Salta al contenuto principale
Asus UL80J Keyboard Replacement
Cosa ti serve
    1. Asus UL80J Keyboard Replacement, Battery: passo 1, immagine 1 di 1
      • Place laptop face down with battery facing up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus UL80J Keyboard Replacement: passo 2, immagine 1 di 1
      • Slide unlock button to the right.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus UL80J Keyboard Replacement: passo 3, immagine 1 di 3 Asus UL80J Keyboard Replacement: passo 3, immagine 2 di 3 Asus UL80J Keyboard Replacement: passo 3, immagine 3 di 3
      • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    1. Asus UL80J Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
      • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus UL80J Keyboard Replacement: passo 5, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      Plastic Cards
      $2.99
      • Gently pry the keyboard up. This will allow you to unclip the keyboard.
      • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
      • Unclipping sounds are normal.
      Chiedi a FixBot
      Aggiungi Commento
      • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus UL80J Keyboard Replacement: passo 7, immagine 1 di 1
      • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
      • Remove the tape from the ribbon cable if needed and remove the keyboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S2-G4, Lacy Spring 2017 Membro di USF Tampa, Team S2-G4, Lacy Spring 2017
USFT-LACY-S17S2G4
3 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 24
Tutti i Tempi: 742
