Salta al contenuto principale
Asus UL80J Key Replacement
Cosa ti serve
  1. Asus UL80J Key Replacement, Battery: passo 1, immagine 1 di 1
    • Place laptop face down with battery facing up.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus UL80J Key Replacement: passo 2, immagine 1 di 1
    • Slide unlock button to the right.
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus UL80J Key Replacement: passo 3, immagine 1 di 3 Asus UL80J Key Replacement: passo 3, immagine 2 di 3 Asus UL80J Key Replacement: passo 3, immagine 3 di 3
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  4. Asus UL80J Key Replacement, Keyboard: passo 4, immagine 1 di 1
    • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Asus UL80J Key Replacement: passo 5, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Gently pry the keyboard up. This will allow you to unclip the keyboard.
    • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
    • Unclipping sounds are normal.
    Chiedi a FixBot
    Aggiungi Commento
    • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
    Chiedi a FixBot
    Aggiungi Commento
  6. Asus UL80J Key Replacement: passo 7, immagine 1 di 1
    • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
    • Remove the tape from the ribbon cable if needed and remove the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Asus UL80J Key Replacement, Key: passo 8, immagine 1 di 2 Asus UL80J Key Replacement, Key: passo 8, immagine 2 di 2
    • Gently insert the plastic opening tool between the key cap and the hinge. Slowly push the screwdriver up. The key should pop up easily.
    Chiedi a FixBot
    Aggiungi Commento
    • Clean the surface underneath the key with a soft brush or condensed air.
    Chiedi a FixBot
    Aggiungi Commento
    • Insert the new key in place of the old key. Ensure the clipping sound occurs.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team S2-G4, Lacy Spring 2017 Membro di USF Tampa, Team S2-G4, Lacy Spring 2017
USFT-LACY-S17S2G4
3 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 32
Tutti i Tempi: 567
