Introduzione
Follow this guide to replace a broken or faulty left fan in your Asus ROG Ally. This is the fan that's on the left-hand side when you're using your device. You can also use this guide to clean the fan.
If your fan is spinning slowly, making loud noises, or isn't spinning at all, you may need to replace it.
Before purchasing a new fan, it's a good idea to remove your current fan and clean off any dust and dirt that may have gotten into it—it's possible this is the problem. If your fan is still having problems after cleaning it, you'll need to get a replacement.
Cosa ti serve
Completely power off your device and unplug all cables.
Attrezzo utilizzato in questo passaggio:FixMat$36.95
Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
Angle the pick upward and push it under the back cover.
Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
Lift the bottom edge of the back cover off the chassis to release the remaining clips.
Remove the back cover.
Use your fingers to peel up and remove the black plastic cover between the fans.
Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
Insert the flat end of a spudger under the center of the battery connector.
Lift the connector straight up and out of its socket to disconnect the battery.
Use a Phillips #00 screwdriver to remove the four screws securing the battery:
Two 9.6 mm‑long screws near the center of the top edge
Two 3.4 mm‑long screws at the left and right edges
With one hand, hold the ribbon cable that runs along the top of the battery out of the way.
With your free hand, lift the battery straight up and remove it.
Insert the point of a spudger between the tape on the upper edge of the fan and the heatsink foam.
Slide the spudger under the length of the tape to separate it from the foam.
Use a Phillips #00 screwdriver to remove the 9.6 mm‑long screw securing the left fan.
Gently lift the fan and set it on top of the heatsink foam so you can access the fan cables.
Use tweezers to peel up and remove the piece of tape securing the fan cables to the motherboard.
Use angled tweezers to pull the fan cable connector straight out of its socket.
