Salta al contenuto principale
Asus Q500A RAM Replacement
Cosa ti serve
    1. Asus Q500A RAM Replacement, RAM: passo 1, immagine 1 di 2 Asus Q500A RAM Replacement, RAM: passo 1, immagine 2 di 2
      • Flip device upside-down.
      • Remove back-plate by unscrewing the two screws on either side of the back-plate.
      • Remove the plastic cover.
      Chiedi a FixBot
      Aggiungi Commento
    2. Asus Q500A RAM Replacement: passo 2, immagine 1 di 1
      • Depending on the model of the device, there will either be one or two sticks of ram.
      • There are two metal brackets holding each ram stick in.
      • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
      Chiedi a FixBot
      Aggiungi Commento
    3. Asus Q500A RAM Replacement: passo 3, immagine 1 di 2 Asus Q500A RAM Replacement: passo 3, immagine 2 di 2
      • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
      Chiedi a FixBot
      Aggiungi Commento
    4. Asus Q500A RAM Replacement: passo 4, immagine 1 di 1
      • To insert the ram line up the ram stick and the slot.
      • Next you will have to push the ram down until it snaps into place.
      • Be careful not to do this too hard, as it can break the ram.
      • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
cameron
Membro da: 02/15/17
319 Reputazione
3 guide realizzate
USF Tampa, Team 12-5, Eyestone Spring 2017 Membro di USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Membri
3 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 29
Tutti i Tempi: 1,101
