Salta al contenuto principale
Asus Eee PC 1201N Keyboard Replacement
Cosa ti serve
  1. Asus Eee PC 1201N Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus Eee PC 1201N Keyboard Replacement: passo 2, immagine 1 di 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus Eee PC 1201N Keyboard Replacement: passo 3, immagine 1 di 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
    Chiedi a FixBot
    Aggiungi Commento
  4. Asus Eee PC 1201N Keyboard Replacement, Keyboard: passo 4, immagine 1 di 2 Asus Eee PC 1201N Keyboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  5. Asus Eee PC 1201N Keyboard Replacement: passo 5, immagine 1 di 2 Asus Eee PC 1201N Keyboard Replacement: passo 5, immagine 2 di 2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team 2-3, Nance Fall 2016 Membro di USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 30
Tutti i Tempi: 778
