Salta al contenuto principale
Asus Eee PC 1201N Display Replacement
Cosa ti serve
  1. Asus Eee PC 1201N Display Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
    Chiedi a FixBot
    Aggiungi Commento
  2. Asus Eee PC 1201N Display Replacement: passo 2, immagine 1 di 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Asus Eee PC 1201N Display Replacement: passo 3, immagine 1 di 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
    Chiedi a FixBot
    Aggiungi Commento
  4. Asus Eee PC 1201N Display Replacement, Display: passo 4, immagine 1 di 2 Asus Eee PC 1201N Display Replacement, Display: passo 4, immagine 2 di 2
    • Remove the six screw on the front cover by using the plastic opening tool. Then, remove the six 4.6mm screws using the J0 Phillips head screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  5. Asus Eee PC 1201N Display Replacement: passo 5, immagine 1 di 1
    • Using the plastic opening tool, separate the over from the netbook.
    Chiedi a FixBot
    Aggiungi Commento
  6. Asus Eee PC 1201N Display Replacement: passo 6, immagine 1 di 1
    • You must separate the hinge cover from the cover before removing the cover.
    Chiedi a FixBot
    Aggiungi Commento
  7. Asus Eee PC 1201N Display Replacement: passo 7, immagine 1 di 1
    • After removing the cover, remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. Asus Eee PC 1201N Display Replacement: passo 8, immagine 1 di 1
    • There are two screws on the left and right side of the display. Remove all four 3mm screws using the J0 Phillips head to separate the LCD from the display cover.
    • The left side will have a magnet covering the bottom screw remove the magnet. Be sure to replace when reassembling.
    Chiedi a FixBot
    Aggiungi Commento
  9. Asus Eee PC 1201N Display Replacement: passo 9, immagine 1 di 1
    • Pull up on the video cable on the back of the LCD display to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-3, Nance Fall 2016 Membro di USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 32
Tutti i Tempi: 949
