Salta al contenuto principale
Astro A50 (2019) Battery Replacement
Cosa ti serve
  1. Astro A50 (2019) Battery Replacement, Battery: passo 1, immagine 1 di 2 Astro A50 (2019) Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the right side ear cushion by pulling toward you on the top tab.
  2. Astro A50 (2019) Battery Replacement: passo 2, immagine 1 di 3 Astro A50 (2019) Battery Replacement: passo 2, immagine 2 di 3 Astro A50 (2019) Battery Replacement: passo 2, immagine 3 di 3
    • Remove the speaker filter by using a prying tool and peeling it off.
    • Work your way around the filter until it comes off.
  3. Astro A50 (2019) Battery Replacement: passo 3, immagine 1 di 3 Astro A50 (2019) Battery Replacement: passo 3, immagine 2 di 3 Astro A50 (2019) Battery Replacement: passo 3, immagine 3 di 3
    • Remove all four 1.5 mm screws using the Phillips #00 screwdriver.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. Astro A50 (2019) Battery Replacement: passo 4, immagine 1 di 3 Astro A50 (2019) Battery Replacement: passo 4, immagine 2 di 3 Astro A50 (2019) Battery Replacement: passo 4, immagine 3 di 3
    • Remove all four 1.5 mm screws holding the motherboard using the Phillips #00 screwdriver.
    • Unplug the battery by pulling the plug.
  5. Astro A50 (2019) Battery Replacement: passo 5, immagine 1 di 2 Astro A50 (2019) Battery Replacement: passo 5, immagine 2 di 2
    • Remove the old battery with a plastic opening tool.
    • Be careful to not puncture the battery or fold it.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 2 persone hanno completato questa guida.
5 Commenti
Where did you source the battery for this? Do you have the part number at least? Astro doesn't sell them.
Thomas Garcia - Replica
I am also looking for this without having to get them from china as it will take 4 to 6 weeks to get it. Any local source for this battery?
billy7183 - Replica
I had to order from China, only batteries that are held domestically I could find were for the gen3/solder only and not the connector style
Luft -
For those with a gen3 a50, the battery is mounted slightly different, you don't need to remove the PCB, just pinch the black tabs holding the outer cover on. See here: https://imgur.com/a/m2Nv2Ze
Wouter V - Replica
I performed this battery replacement. I sourced a new battery from another new A50 Gen 4 that was firmware bricked.
I’m having an issue charging the new battery with the base station. The headset does not seem to accept a charge from the base station however it will charge via a micro USB cable plugged into a usb wall brick.
I believe the issue is related to the battery not being calibrated to the old headset. Any ideas?
William Patterson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 27
Ultimi 7 Giorni: 141
Ultimi 30 Giorni: 557
Tutti i Tempi: 9,168
