Salta al contenuto principale
Astro A20 Cushion Replacement
Cosa ti serve
    1. Astro A20 Cushion  Replacement, Cushion: passo 1, immagine 1 di 1
      • Place one hand on the hard side of the headset ear portion and on the cushion.
      • Lift the small portion on the edge of the cushion.
      Chiedi a FixBot
      Aggiungi Commento
    2. Astro A20 Cushion  Replacement: passo 2, immagine 1 di 1
      • Slide the metal spudger underneath the lift part of the ear cushion.
      • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
      Chiedi a FixBot
      Aggiungi Commento
    3. Astro A20 Cushion  Replacement: passo 3, immagine 1 di 2 Astro A20 Cushion  Replacement: passo 3, immagine 2 di 2
      • Remove the ear cushion from the headset.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
The lighting is quite poor. I can't see what you're doing at all.
It's also missing a lot of information. Are they glued down? Are you able to get the ear cups off intact so they can be replaced after your wash them?
Vitrified Valkyrie - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 22
Ultimi 30 giorni: 74
Tutti i Tempi: 7,934
