Salta al contenuto principale
Astro A20 Microphone Replacement
Cosa ti serve
    1. Astro A20  Microphone Replacement, Cushion: passo 1, immagine 1 di 1
      • Place one hand on the hard side of the headset ear portion and on the cushion.
      • Lift the small portion on the edge of the cushion.
      Chiedi a FixBot
      Aggiungi Commento
    2. Astro A20  Microphone Replacement: passo 2, immagine 1 di 1
      • Slide the metal spudger underneath the lift part of the ear cushion.
      • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
      Chiedi a FixBot
      Aggiungi Commento
    3. Astro A20  Microphone Replacement: passo 3, immagine 1 di 2 Astro A20  Microphone Replacement: passo 3, immagine 2 di 2
      • Remove the ear cushion from the headset.
      Chiedi a FixBot
      Aggiungi Commento
    1. Astro A20  Microphone Replacement, Microphone: passo 4, immagine 1 di 1
      • Place one hand on the back of the speaker.
      Chiedi a FixBot
      Aggiungi Commento
    2. Astro A20  Microphone Replacement: passo 5, immagine 1 di 2 Astro A20  Microphone Replacement: passo 5, immagine 2 di 2
      • Remove the four 7mm screws with a Phillips #1 screwdriver.
      • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
      Chiedi a FixBot
      Aggiungi Commento
    3. Astro A20  Microphone Replacement: passo 6, immagine 1 di 2 Astro A20  Microphone Replacement: passo 6, immagine 2 di 2
      • Lift the speaker area.
      • Disconnect the wires that connect the microphone.
      • Remove the 7mm screw with a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
5Commenti sulla guida
worked for me….thanks
Thompson Crusher - Rispondi Condividi
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Rispondi Condividi
were? are you getting the new mic from? please link the site
jrod6t9 - Rispondi Condividi
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 19
Ultimi 30 giorni: 124
Tutti i Tempi: 15,734
