Salta al contenuto principale
Apple Studio Display M7649 Inverter Replacement
Cosa ti serve
    1. Apple Studio Display M7649 Inverter Replacement, Stand: passo 1, immagine 1 di 2 Apple Studio Display M7649 Inverter Replacement, Stand: passo 1, immagine 2 di 2
      • Lay the display facing down with the stand away from you.
      • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
      Chiedi a FixBot
      Aggiungi Commento
    1. Apple Studio Display M7649 Inverter Replacement, Panels: passo 2, immagine 1 di 1
      • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple Studio Display M7649 Inverter Replacement: passo 3, immagine 1 di 1
      • Rotate the display so the legs of the display are now facing you
      • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple Studio Display M7649 Inverter Replacement: passo 4, immagine 1 di 1
      • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
      Chiedi a FixBot
      Aggiungi Commento
    1. Apple Studio Display M7649 Inverter Replacement, Metal EMI Shield: passo 5, immagine 1 di 1
      • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple Studio Display M7649 Inverter Replacement: passo 6, immagine 1 di 1
      • Now locate and remove the lone Phillips screw holding the EMI shield to the display
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple Studio Display M7649 Inverter Replacement: passo 7, immagine 1 di 2 Apple Studio Display M7649 Inverter Replacement: passo 7, immagine 2 di 2
      • Now that the screw has been removed, slide the panel towards your body and lift it out.
      • You may need to remove the clear USB port cover to remove the metal EMI shield.
      Chiedi a FixBot
      Aggiungi Commento
    1. Apple Studio Display M7649 Inverter Replacement, Inverter: passo 8, immagine 1 di 1
      • Remove these three screws holding the board to the display
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple Studio Display M7649 Inverter Replacement: passo 9, immagine 1 di 1
      • Remove these five cables connection the inverter to the backlights and logic board.
      • Taking note where they connect to for reassembly
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple Studio Display M7649 Inverter Replacement: passo 10, immagine 1 di 1
      • Remove and replace the inverter
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Andrew Tsao
Membro da: 01/19/10
186 Reputazione
5 guide realizzate
Cal Poly, Team 3-20, Maness Winter 2010 Membro di Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Membri
39 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 14
Ultimi 30 giorni: 41
Tutti i Tempi: 7,896
