Salta al contenuto principale
Apple PowerBook G3 400 RAM Replacement
Cosa ti serve
  1. Apple PowerBook G3 400 RAM Replacement, Keyboard: passo 1, immagine 1 di 1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
    Chiedi a FixBot
    Aggiungi Commento
  2. Apple PowerBook G3 400 RAM Replacement: passo 2, immagine 1 di 1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
    Chiedi a FixBot
    Aggiungi Commento
  3. Apple PowerBook G3 400 RAM Replacement: passo 3, immagine 1 di 1
    • Your computer should look approximately like this.
    Chiedi a FixBot
    Aggiungi Commento
  4. Apple PowerBook G3 400 RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Lift the heat shield up and toward you.
    Chiedi a FixBot
    Aggiungi Commento
  5. Apple PowerBook G3 400 RAM Replacement: passo 5, immagine 1 di 1
    • Pull the PRAM battery cable vertically upward to disconnect it.
    • Remove the battery by pulling up and to the left.
    Chiedi a FixBot
    Aggiungi Commento
  6. Apple PowerBook G3 400 RAM Replacement: passo 6, immagine 1 di 1
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the long silver Phillips #1 screw from the heat sink.
    Chiedi a FixBot
    Aggiungi Commento
  7. Apple PowerBook G3 400 RAM Replacement: passo 7, immagine 1 di 1
    • Lift up the heat sink unit from the left side and remove.
    Chiedi a FixBot
    Aggiungi Commento
  8. Apple PowerBook G3 400 RAM Replacement: passo 8, immagine 1 di 1
    • Lift the processor on the right side and pull directly up.
    • The RAM chips should be in the slots on the processor.
    Chiedi a FixBot
    Aggiungi Commento
  9. Apple PowerBook G3 400 RAM Replacement: passo 9, immagine 1 di 1
    • After removing the RAM, your laptop should now look like this.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Ian
Membro da: 04/18/11
57 Reputazione
Una guida realizzata
Cal Poly, Team 4-2, Regan Spring 2011 Membro di Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 32
Tutti i Tempi: 2,504
