Salta al contenuto principale
Apple PowerBook G3 400 Display Replacement
Cosa ti serve
    1. Apple PowerBook G3 400 Display Replacement, Keyboard: passo 1, immagine 1 di 1
      • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
      • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple PowerBook G3 400 Display Replacement: passo 2, immagine 1 di 1
      • Pull the keyboard ribbon vertically from the logic board to release connection.
      • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
      • Remove battery and CD/DVD drives before proceeding any further.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple PowerBook G3 400 Display Replacement: passo 3, immagine 1 di 1
      • Your computer should look approximately like this.
      Chiedi a FixBot
      Aggiungi Commento
    1. Apple PowerBook G3 400 Display Replacement, RAM: passo 4, immagine 1 di 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
      • Lift the heat shield up and toward you.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple PowerBook G3 400 Display Replacement: passo 5, immagine 1 di 1
      • Pull the PRAM battery cable vertically upward to disconnect it.
      • Remove the battery by pulling up and to the left.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple PowerBook G3 400 Display Replacement: passo 6, immagine 1 di 1
      • Remove the two T8 Torx screws that attach the heat sink to the processor.
      • Remove the long silver Phillips #1 screw from the heat sink.
      Chiedi a FixBot
      Aggiungi Commento
    4. Apple PowerBook G3 400 Display Replacement: passo 7, immagine 1 di 1
      • Lift up the heat sink unit from the left side and remove.
      Chiedi a FixBot
      Aggiungi Commento
    5. Apple PowerBook G3 400 Display Replacement: passo 8, immagine 1 di 1
      • Lift the processor on the right side and pull directly up.
      • The RAM chips should be in the slots on the processor.
      Chiedi a FixBot
      Aggiungi Commento
    6. Apple PowerBook G3 400 Display Replacement: passo 9, immagine 1 di 1
      • After removing the RAM, your laptop should now look like this.
      Chiedi a FixBot
      Aggiungi Commento
    1. Apple PowerBook G3 400 Display Replacement, Hard Drive: passo 10, immagine 1 di 1
      • Locate the orange tab, which should be just left of the hard-drive.
      • You must disconnect this orange tab from the logic board to enable the next step.
      • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple PowerBook G3 400 Display Replacement: passo 11, immagine 1 di 1
      • Grab the plastic strip shown here and gently remove, pulling up and left.
      • Pull left to avoid the hard drive catching the casing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple PowerBook G3 400 Display Replacement: passo 12, immagine 1 di 1
      • Once you have removed the hard-drive, your laptop should like this.
      Chiedi a FixBot
      Aggiungi Commento
    1. Apple PowerBook G3 400 Display Replacement, Modem: passo 13, immagine 1 di 1
      • Remove the single black Torx screw from the modem.
      • Remove the black rectangle that is being held on by the one Torx screw.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple PowerBook G3 400 Display Replacement: passo 14, immagine 1 di 1
      • Using your fingers, lift the modem from the socket it is plugged into.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple PowerBook G3 400 Display Replacement: passo 15, immagine 1 di 1
      • Disconnect the cable that is attached to the end of the modem to remove the modem.
      Chiedi a FixBot
      Aggiungi Commento
    1. Apple PowerBook G3 400 Display Replacement, Display: passo 16, immagine 1 di 1
      • Your computer will look approximately like this.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple PowerBook G3 400 Display Replacement: passo 17, immagine 1 di 1
      • Push the display back.
      • Put your index finger under the power button and gently pull the clutch cover back.
      • Repeat for the left side.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple PowerBook G3 400 Display Replacement: passo 18, immagine 1 di 1
      • Lift the clutch cover up and off. Pull it towards yourself.
      Chiedi a FixBot
      Aggiungi Commento
    4. Apple PowerBook G3 400 Display Replacement: passo 19, immagine 1 di 1
      • Disconnect the display cable from the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    5. Apple PowerBook G3 400 Display Replacement: passo 20, immagine 1 di 1
      • Remove the Torx screw that holds the display cable.
      • Pull out thick display inverter board by pulling it up and out. Two tabs will be holding it in place, you need to get pass these to pull the board free.
      Chiedi a FixBot
      Aggiungi Commento
    6. Apple PowerBook G3 400 Display Replacement: passo 21, immagine 1 di 1
      • Disconnect the white inverter cable. Pull it towards the left.
      Chiedi a FixBot
      Aggiungi Commento
    7. Apple PowerBook G3 400 Display Replacement: passo 22, immagine 1 di 1
      • Disconnect the inverter plug by pulling it up from the logib board.
      Chiedi a FixBot
      Aggiungi Commento
    8. Apple PowerBook G3 400 Display Replacement: passo 23, immagine 1 di 1
      • Turn the laptop around.
      • Open the port door.
      • Remove the four Torx screws.
      Chiedi a FixBot
      Aggiungi Commento
    9. Apple PowerBook G3 400 Display Replacement: passo 24, immagine 1 di 1
      • Turn the laptop so the front faces you.
      • Pull the black Airport antenna up.
      Chiedi a FixBot
      Aggiungi Commento
    10. Apple PowerBook G3 400 Display Replacement: passo 25, immagine 1 di 1
      • Pull the display up as you hold it firmly with both hands.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Isabelle
Membro da: 04/18/11
11 Reputazione
Una guida realizzata
Cal Poly, Team 4-2, Regan Spring 2011 Membro di Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 2,171
