Salta al contenuto principale
Apple LED Cinema Display 27" LED Panel Replacement
Cosa ti serve
    1. Apple LED Cinema Display 27" LED Panel Replacement, LED panel: passo 1, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement, LED panel: passo 1, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement, LED panel: passo 1, immagine 3 di 3
      • Before beginning any work on your Mac: Unplug the computer and wait for 2 minutes in order for the power supply's capacitors to discharge.
      • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
      • The all-in-one cable located underneath the power cable can NOT get disconnected from the rest of the enclosure.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple LED Cinema Display 27" LED Panel Replacement: passo 2, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 2, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 2, immagine 3 di 3
      • Glass panel can be removed in various ways:
      • Lay the unit on its back and press clean suction cups in opposite corners on the glass panel, or...
      • Lay the unit on its back and press clean suction cups on top.
      • Lift the glass panel up and off.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple LED Cinema Display 27" LED Panel Replacement: passo 3, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 3, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 3, immagine 3 di 3
      • First Steps Remove the glass panel as shown on step 2.
      • Upon disassembly, handle the LED panel only from the metal railings on either side and avoid touching the panel as much as possible.
      • Do not press on the front surface of the LED panel when handling, as this could cause the pixels from the panel to malfunction and/or stop working.
      Chiedi a FixBot
      Aggiungi Commento
    4. Apple LED Cinema Display 27" LED Panel Replacement: passo 4, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 4, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 4, immagine 3 di 3
      • Remove the twelve, 10 mm Torx T10 screws around the border of the display frame.
      • Be sure not to overtighten the LED screws during reassembly, as it could cause light leakage after the unit is reassembled.
      Chiedi a FixBot
      Aggiungi Commento
    5. Apple LED Cinema Display 27" LED Panel Replacement: passo 5, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 5, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 5, immagine 3 di 3
      • Use the black tabs to raise the bottom edge of the LCD a few inches to access the cables inside.
      • Tilt the display up no more than 4 inches (10 cm). Pulling the display too far could damage the cables or connectors.
      Chiedi a FixBot
      Aggiungi Commento
    6. Apple LED Cinema Display 27" LED Panel Replacement: passo 6, immagine 1 di 2 Apple LED Cinema Display 27" LED Panel Replacement: passo 6, immagine 2 di 2
      • Avoid coming in close contact or touching any components of the Power Supply.
      • Looking into the gap under the LCD, disconnect four (4) cables:
      • DisplayPort
      • Function
      • Ground pin
      • LED backlight driver
      • Verify that all cables are firmly seated into connectors during reassembly. An insecure cable connection can cause image flicker.
      Chiedi a FixBot
      Aggiungi Commento
    7. Apple LED Cinema Display 27" LED Panel Replacement: passo 7, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 7, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 7, immagine 3 di 3
      • Peel back the mylar and foil tape on the DisplayPort cable on the back of the LED panel.
      • Squeeze the sides of connector and pull it out.
      • Make sure the 24 pin cable is correctly aligned with the LED panel upon reassembly.
      Chiedi a FixBot
      Aggiungi Commento
    8. Apple LED Cinema Display 27" LED Panel Replacement: passo 8, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 8, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 8, immagine 3 di 3
      • Squeeze the sides of the function cable connector on the top left edge of the logic board and pull it straight out.
      • Make sure to align the function cable correctly with the logic board during reassembly.
      Chiedi a FixBot
      Aggiungi Commento
    9. Apple LED Cinema Display 27" LED Panel Replacement: passo 9, immagine 1 di 2 Apple LED Cinema Display 27" LED Panel Replacement: passo 9, immagine 2 di 2
      • Close-up of the ground cable at top left of logic board. Remove the 10 mm Torx T10 screw from top left corner of logic board.
      • Disconnect the ground cable.
      • Avoid touching the double pins on the top left corner of the logic board with a screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    10. Apple LED Cinema Display 27" LED Panel Replacement: passo 10, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 10, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 10, immagine 3 di 3
      • Pinch the LED backlight driver cable on the underside of the center right edge of the logic board and pull straight out.
      • Avoid putting force on the logic board to bend as deformation of a logic board can cause issues.
      Chiedi a FixBot
      Aggiungi Commento
    11. Apple LED Cinema Display 27" LED Panel Replacement: passo 11, immagine 1 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 11, immagine 2 di 3 Apple LED Cinema Display 27" LED Panel Replacement: passo 11, immagine 3 di 3
      • Handle the LCD panel by the edges and lift it upwards until it separates from the rest of the enclosure.
      • This guide can be followed in reserve in order to perform an installation and reassembly of the LED panel to the rest of the enclosure.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
In order to put everything back to its original place, we will need the new LCD panel and to follow the above steps in reverse.
Altre 8 persone hanno completato questa guida.
Documenti allegati
Iason Kotakis
Membro da: 01/10/21
393 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 51
Ultimi 30 giorni: 247
Tutti i Tempi: 17,608
