Introduzione
If you are having trouble with powering your computer, it is possible that your power converter needs to be replaced. If that is the case, this guide will show you how to locate and carefully remove the power converter step by step.
Cosa ti serve
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Remove the two 7.7mm length Phillips screws that secure the power converter.
Altre 7 persone hanno completato questa guida.
