Salta al contenuto principale
AmazonBasics BTV1 Battery Replacement
Cosa ti serve
    1. AmazonBasics BTV1 Battery Replacement, Battery: passo 1, immagine 1 di 2 AmazonBasics BTV1 Battery Replacement, Battery: passo 1, immagine 2 di 2
      • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
      • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
      Chiedi a FixBot
      Aggiungi Commento
    2. AmazonBasics BTV1 Battery Replacement: passo 2, immagine 1 di 2 AmazonBasics BTV1 Battery Replacement: passo 2, immagine 2 di 2
      • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
      • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
      Chiedi a FixBot
      Aggiungi Commento
    3. AmazonBasics BTV1 Battery Replacement: passo 3, immagine 1 di 2 AmazonBasics BTV1 Battery Replacement: passo 3, immagine 2 di 2
      • Tilt the case downwards until the speakers fall out of their housings.
      • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
      Chiedi a FixBot
      Aggiungi Commento
    4. AmazonBasics BTV1 Battery Replacement: passo 4, immagine 1 di 2 AmazonBasics BTV1 Battery Replacement: passo 4, immagine 2 di 2
      • Gently pull each plastic connector from the motherboard.
      • Take a note of which connector goes with each component for easy reassembly.
      • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. AmazonBasics BTV1 Battery Replacement: passo 5, immagine 1 di 2 AmazonBasics BTV1 Battery Replacement: passo 5, immagine 2 di 2
      • Lift the motherboard off the face plate, exposing the battery.
      • Lift the battery out of its housing.
      • Use caution when using tools around the battery; batteries can be dangerous if punctured.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
USF Tampa, Team 14-2, Lacy Spring 2016 Membro di USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Membri
10 guide realizzate
8Commenti sulla guida
donde consigo la bateria?
bnet_d72 - Rispondi Condividi
Nice job, Chris! Thank you.
David Printz - Rispondi Condividi
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Rispondi Condividi
Need information on where to get a replacement battery!
dan - Rispondi Condividi
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 31
Tutti i Tempi: 3,779
