Salta al contenuto principale
Amazon Fire HD 8 12th Gen Camera Replacement
Cosa ti serve
  1. Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: passo 1, immagine 1 di 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: passo 1, immagine 2 di 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: passo 1, immagine 3 di 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
    Chiedi a FixBot
    Aggiungi Commento
  2. Amazon Fire HD 8 12th Gen Camera Replacement: passo 2, immagine 1 di 2 Amazon Fire HD 8 12th Gen Camera Replacement: passo 2, immagine 2 di 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Amazon Fire HD 8 12th Gen Camera Replacement, Camera: passo 3, immagine 1 di 2 Amazon Fire HD 8 12th Gen Camera Replacement, Camera: passo 3, immagine 2 di 2
    • Using the iFixit opening tool, disconnect the battery from the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  4. Amazon Fire HD 8 12th Gen Camera Replacement: passo 4, immagine 1 di 3 Amazon Fire HD 8 12th Gen Camera Replacement: passo 4, immagine 2 di 3 Amazon Fire HD 8 12th Gen Camera Replacement: passo 4, immagine 3 di 3
    • Disconnect the camera from the motherboard by unplugging the orange wiring.
    • Heat the area of the back camera up loosening the glue holding it in place.
    • Be careful when using hot tools and removing hot parts.
    Chiedi a FixBot
    Aggiungi Commento
  5. Amazon Fire HD 8 12th Gen Camera Replacement: passo 5, immagine 1 di 3 Amazon Fire HD 8 12th Gen Camera Replacement: passo 5, immagine 2 di 3 Amazon Fire HD 8 12th Gen Camera Replacement: passo 5, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Once disconnected from the motherboard and heated up, use tweezers to remove the old camera.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 21
Tutti i Tempi: 397
