Salta al contenuto principale
Amazon Fire HD 8 12th Gen Button Replacement
Cosa ti serve
  1. Amazon Fire HD 8 12th Gen Button Replacement, Buttons: passo 1, immagine 1 di 3 Amazon Fire HD 8 12th Gen Button Replacement, Buttons: passo 1, immagine 2 di 3 Amazon Fire HD 8 12th Gen Button Replacement, Buttons: passo 1, immagine 3 di 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
    Chiedi a FixBot
    Aggiungi Commento
  2. Amazon Fire HD 8 12th Gen Button Replacement: passo 2, immagine 1 di 2 Amazon Fire HD 8 12th Gen Button Replacement: passo 2, immagine 2 di 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 48
Tutti i Tempi: 623
