Salta al contenuto principale
Amazon Echo Tweeter Assembly Replacement
Cosa ti serve
    1. Amazon Echo Tweeter Assembly Replacement, Power and Speaker Driver Board: passo 1, immagine 1 di 1
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      Chiedi a FixBot
      Aggiungi Commento
    2. Amazon Echo Tweeter Assembly Replacement: passo 2, immagine 1 di 3 Amazon Echo Tweeter Assembly Replacement: passo 2, immagine 2 di 3 Amazon Echo Tweeter Assembly Replacement: passo 2, immagine 3 di 3
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      Chiedi a FixBot
      Aggiungi Commento
    3. Amazon Echo Tweeter Assembly Replacement: passo 3, immagine 1 di 1
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      Chiedi a FixBot
      Aggiungi Commento
    4. Amazon Echo Tweeter Assembly Replacement: passo 4, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      Chiedi a FixBot
      Aggiungi Commento
    5. Amazon Echo Tweeter Assembly Replacement: passo 5, immagine 1 di 2 Amazon Echo Tweeter Assembly Replacement: passo 5, immagine 2 di 2
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      Chiedi a FixBot
      Aggiungi Commento
    6. Amazon Echo Tweeter Assembly Replacement: passo 6, immagine 1 di 3 Amazon Echo Tweeter Assembly Replacement: passo 6, immagine 2 di 3 Amazon Echo Tweeter Assembly Replacement: passo 6, immagine 3 di 3
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      Chiedi a FixBot
      Aggiungi Commento
    1. Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: passo 7, immagine 1 di 2 Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: passo 7, immagine 2 di 2
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      Chiedi a FixBot
      Aggiungi Commento
    2. Amazon Echo Tweeter Assembly Replacement: passo 8, immagine 1 di 1
      • Peel off the black fabric wrapped around the Echo.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      Chiedi a FixBot
      Aggiungi Commento
    3. Amazon Echo Tweeter Assembly Replacement: passo 9, immagine 1 di 3 Amazon Echo Tweeter Assembly Replacement: passo 9, immagine 2 di 3 Amazon Echo Tweeter Assembly Replacement: passo 9, immagine 3 di 3
      • Remove the four 42.8 mm T10 Torx screws around the tweeter.
      • Lift the tweeter and its attached housing from the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 3-3, Wollert Spring 2016 Membro di USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Membri
25 guide realizzate
3Commenti sulla guida
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - Rispondi Condividi
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - Rispondi Condividi
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 39
Tutti i Tempi: 4,406
