Salta al contenuto principale
Amazon Echo Show 15 Camera Replacement
Cosa ti serve
    1. Amazon Echo Show 15 Camera Replacement, Back Panel: passo 1, immagine 1 di 3 Amazon Echo Show 15 Camera Replacement, Back Panel: passo 1, immagine 2 di 3 Amazon Echo Show 15 Camera Replacement, Back Panel: passo 1, immagine 3 di 3
      • Remove the four white stickers on your device's back panel.
      • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
      • A hair dryer may work best for this step.
      Chiedi a FixBot
      Aggiungi Commento
    2. Amazon Echo Show 15 Camera Replacement: passo 2, immagine 1 di 3 Amazon Echo Show 15 Camera Replacement: passo 2, immagine 2 di 3 Amazon Echo Show 15 Camera Replacement: passo 2, immagine 3 di 3
      • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
      • Pop the sides and remove the back panel of the device.
      Chiedi a FixBot
      Aggiungi Commento
    1. Amazon Echo Show 15 Camera Replacement, Inner Black Panel: passo 3, immagine 1 di 3 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: passo 3, immagine 2 di 3 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: passo 3, immagine 3 di 3
      • In the top right corner you will find a small black panel.
      • Remove the five 2 mm screws with a Torx T5 screwdriver.
      • Remove the two 5 mm with a Torx T3 screwdriver.
      • Remove both ends of the connector from the main device.
      • Remove the black panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. Amazon Echo Show 15 Camera Replacement, Camera: passo 4, immagine 1 di 3 Amazon Echo Show 15 Camera Replacement, Camera: passo 4, immagine 2 di 3 Amazon Echo Show 15 Camera Replacement, Camera: passo 4, immagine 3 di 3
      • Remove the small connector from the main device.
      • Disconnect the camera cord from the motherboard.
      • Pull the camera out of the main device.
      • The camera is connected to the main device with adhesive. You will need to use a bit more force to get it out.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 23
Tutti i Tempi: 413
