Salta al contenuto principale
Amazon Echo Show 10 3rd Gen Woofer Replacement
Cosa ti serve
  1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: passo 1, immagine 1 di 2 Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: passo 1, immagine 2 di 2
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Woofer Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the six 13 mm screws along the perimeter of the speaker.
  3. Amazon Echo Show 10 3rd Gen Woofer Replacement: passo 3, immagine 1 di 2 Amazon Echo Show 10 3rd Gen Woofer Replacement: passo 3, immagine 2 di 2
    • Use an opening tool to pry up along the edge of the speaker.
    • Gently lift the woofer out of the device.
    • The woofer is connected to a cable so don't yank it out or you will damage the connector.
  4. Amazon Echo Show 10 3rd Gen Woofer Replacement: passo 4, immagine 1 di 1
    • Tilt the woofer so the side with the cables is angled upwards.
    • Desolder the three separate cable connectors from the woofer attached to the plate using a soldering iron.
    • For information on soldering, refer to the How to Solder and Desolder Connections guide.
  5. Amazon Echo Show 10 3rd Gen Woofer Replacement: passo 5, immagine 1 di 1
    • After desoldering the three cables, lift the woofer out of the shell of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 95
