Salta al contenuto principale
Amazon Echo LED/Microphone Board Replacement
Cosa ti serve
    1. Amazon Echo LED/Microphone Board Replacement, Power and Speaker Driver Board: passo 1, immagine 1 di 1
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      Chiedi a FixBot
      Aggiungi Commento
    2. Amazon Echo LED/Microphone Board Replacement: passo 2, immagine 1 di 3 Amazon Echo LED/Microphone Board Replacement: passo 2, immagine 2 di 3 Amazon Echo LED/Microphone Board Replacement: passo 2, immagine 3 di 3
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      Chiedi a FixBot
      Aggiungi Commento
    3. Amazon Echo LED/Microphone Board Replacement: passo 3, immagine 1 di 1
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      Chiedi a FixBot
      Aggiungi Commento
    4. Amazon Echo LED/Microphone Board Replacement: passo 4, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      Chiedi a FixBot
      Aggiungi Commento
    5. Amazon Echo LED/Microphone Board Replacement: passo 5, immagine 1 di 2 Amazon Echo LED/Microphone Board Replacement: passo 5, immagine 2 di 2
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      Chiedi a FixBot
      Aggiungi Commento
    6. Amazon Echo LED/Microphone Board Replacement: passo 6, immagine 1 di 3 Amazon Echo LED/Microphone Board Replacement: passo 6, immagine 2 di 3 Amazon Echo LED/Microphone Board Replacement: passo 6, immagine 3 di 3
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      Chiedi a FixBot
      Aggiungi Commento
    1. Amazon Echo LED/Microphone Board Replacement, Motherboard: passo 7, immagine 1 di 2 Amazon Echo LED/Microphone Board Replacement, Motherboard: passo 7, immagine 2 di 2
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      Chiedi a FixBot
      Aggiungi Commento
    2. Amazon Echo LED/Microphone Board Replacement: passo 8, immagine 1 di 1
      • Peel off the black fabric wrapped around the device.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      Chiedi a FixBot
      Aggiungi Commento
    3. Amazon Echo LED/Microphone Board Replacement: passo 9, immagine 1 di 2 Amazon Echo LED/Microphone Board Replacement: passo 9, immagine 2 di 2
      • Remove the four 9.7 mm T10 screws.
      Chiedi a FixBot
      Aggiungi Commento
    4. Amazon Echo LED/Microphone Board Replacement: passo 10, immagine 1 di 3 Amazon Echo LED/Microphone Board Replacement: passo 10, immagine 2 di 3 Amazon Echo LED/Microphone Board Replacement: passo 10, immagine 3 di 3
      • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
      • Pull the two ribbon cables from their connectors on the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. Amazon Echo LED/Microphone Board Replacement: passo 11, immagine 1 di 1
      • Lift the motherboard up from the Echo.
      Chiedi a FixBot
      Aggiungi Commento
    1. Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: passo 12, immagine 1 di 2 Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: passo 12, immagine 2 di 2
      • Remove the 9.7 mm T10 Torx screw from the opposite side of the Echo.
      Chiedi a FixBot
      Aggiungi Commento
    2. Amazon Echo LED/Microphone Board Replacement: passo 13, immagine 1 di 2 Amazon Echo LED/Microphone Board Replacement: passo 13, immagine 2 di 2
      • Unclip and remove the top volume ring assembly from the Echo.
      Chiedi a FixBot
      Aggiungi Commento
    3. Amazon Echo LED/Microphone Board Replacement: passo 14, immagine 1 di 2 Amazon Echo LED/Microphone Board Replacement: passo 14, immagine 2 di 2
      • Unscrew the four 9.7 mm T9 torx screws from the bottom of the volume ring assembly.
      Chiedi a FixBot
      Aggiungi Commento
    4. Amazon Echo LED/Microphone Board Replacement: passo 15, immagine 1 di 1
      • Turn the assembly over and lift up the plate with the buttons.
      Chiedi a FixBot
      Aggiungi Commento
    5. Amazon Echo LED/Microphone Board Replacement: passo 16, immagine 1 di 2 Amazon Echo LED/Microphone Board Replacement: passo 16, immagine 2 di 2
      • Turn the plate over, then lift and remove black gear and the white plastic ring.
      Chiedi a FixBot
      Aggiungi Commento
    6. Amazon Echo LED/Microphone Board Replacement: passo 17, immagine 1 di 3 Amazon Echo LED/Microphone Board Replacement: passo 17, immagine 2 di 3 Amazon Echo LED/Microphone Board Replacement: passo 17, immagine 3 di 3
      • Remove the ribbon cable by lifting the brown latch on the ZIF connector.
      • Lift the LED/Microphone board from the plate.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 3-3, Wollert Spring 2016 Membro di USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Membri
25 guide realizzate
2Commenti sulla guida
So in Step 15, I’m having a problem reassembling the Plate with buttons back into the volume ring… can someone give me any tricks/pointers please?
JaxyB - Rispondi Condividi
Where can i buy this LED/Microphone board for replacement?
Tuan Nguyen - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 14
Ultimi 30 giorni: 79
Tutti i Tempi: 15,708
