Salta al contenuto principale
AlphaSmart Pro Lithium Coin Battery Replacement
Cosa ti serve
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, immagine 1 di 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, immagine 2 di 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: passo 1, immagine 3 di 3
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: passo 2, immagine 1 di 2 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: passo 2, immagine 2 di 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    Chiedi a FixBot
    Aggiungi Commento
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: passo 3, immagine 1 di 2 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: passo 3, immagine 2 di 2
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: passo 4, immagine 1 di 2 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: passo 4, immagine 2 di 2
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Katy Beth Culp
Membro da: 10/13/14
1 Reputazione
2 guide realizzate
Clemson, Team 1-1, Benson Fall 2014 Membro di Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 42
Tutti i Tempi: 1,423
