Salta al contenuto principale
AlphaSmart Pro Front Panel Replacement
Cosa ti serve
  1. AlphaSmart Pro Front Panel Replacement, Separating Panels: passo 1, immagine 1 di 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: passo 1, immagine 2 di 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: passo 1, immagine 3 di 3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: passo 2, immagine 1 di 2 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: passo 2, immagine 2 di 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: passo 3, immagine 1 di 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: passo 3, immagine 2 di 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: passo 3, immagine 3 di 3
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Clemson, Team 1-1, Benson Fall 2014 Membro di Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 28
Tutti i Tempi: 564
