Salta al contenuto principale
Alienware X51 R2/R3 CPU Replacement
Cosa ti serve
  1. Alienware X51 R2/R3 CPU Replacement, CPU (Processor): passo 1, immagine 1 di 1
    • The first step is to unscrew this screw. After that you want to slide the case cover off of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  2. Alienware X51 R2/R3 CPU Replacement: passo 2, immagine 1 di 1
    • After the Case is open, you want to disconnect the cable to the LED's on the system case.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alienware X51 R2/R3 CPU Replacement: passo 3, immagine 1 di 1
    • You will need to unscrew two screws from the fan cover. The screws are located in the red markers. Then you will gently lift the cover out of the case.
    • Afterwards, you will need to unplug the fan from the motherboard at the blue marker.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alienware X51 R2/R3 CPU Replacement: passo 4, immagine 1 di 1
    • Using the screwdriver, unscrew the 4 screws securing the heat sink and fan to the motherboard. THE SCREWS DO NOT COME OUT ALL THE WAY.
    • Afterward, lift the heat sink out of the case to reveal the processor.
    Chiedi a FixBot
    Aggiungi Commento
  5. Alienware X51 R2/R3 CPU Replacement: passo 5, immagine 1 di 1
    • If there is already thermal paste on the heat sink and/or processor, clean it off using the ArctiClean.
    • Carefully move the lever to release the processor bracket. Then, flip the bracket over, and CAREFULLY remove the processor BY THE EDGES.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order with the new processor installed. Don't forget to apply thermal grease to the new CPU.
Altre 2 persone hanno completato questa guida.
rcschwartz709
Membro da: 07/02/16
220 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 18
Ultimi 30 giorni: 65
Tutti i Tempi: 3,269
