Salta al contenuto principale
Alienware M17x RAM Replacement
Cosa ti serve
  1. Alienware M17x RAM Replacement, Battery: passo 1, immagine 1 di 2 Alienware M17x RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    Chiedi a FixBot
    Aggiungi Commento
  2. Alienware M17x RAM Replacement: passo 2, immagine 1 di 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alienware M17x RAM Replacement: passo 3, immagine 1 di 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alienware M17x RAM Replacement: passo 4, immagine 1 di 2 Alienware M17x RAM Replacement: passo 4, immagine 2 di 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    Chiedi a FixBot
    Aggiungi Commento
  5. Alienware M17x RAM Replacement, RAM: passo 5, immagine 1 di 2 Alienware M17x RAM Replacement, RAM: passo 5, immagine 2 di 2
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
    Chiedi a FixBot
    Aggiungi Commento
  6. Alienware M17x RAM Replacement: passo 6, immagine 1 di 2 Alienware M17x RAM Replacement: passo 6, immagine 2 di 2
    • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
    • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
    Chiedi a FixBot
    Aggiungi Commento
  7. Alienware M17x RAM Replacement: passo 7, immagine 1 di 1
    • Remove the bottom RAM card in a similar manner.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 31
Tutti i Tempi: 858
