Salta al contenuto principale
Alienware M17x Display Assembly Replacement
Cosa ti serve
  1. Alienware M17x Display Assembly Replacement, Battery: passo 1, immagine 1 di 2 Alienware M17x Display Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    Chiedi a FixBot
    Aggiungi Commento
  2. Alienware M17x Display Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alienware M17x Display Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alienware M17x Display Assembly Replacement: passo 4, immagine 1 di 2 Alienware M17x Display Assembly Replacement: passo 4, immagine 2 di 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    Chiedi a FixBot
    Aggiungi Commento
  5. Alienware M17x Display Assembly Replacement, Display Assembly: passo 5, immagine 1 di 1
    • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
    Chiedi a FixBot
    Aggiungi Commento
  6. Alienware M17x Display Assembly Replacement: passo 6, immagine 1 di 3 Alienware M17x Display Assembly Replacement: passo 6, immagine 2 di 3 Alienware M17x Display Assembly Replacement: passo 6, immagine 3 di 3
    • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
    • Use the spudger to remove the siding from the bottom of the frame near the hinges.
    • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
    Chiedi a FixBot
    Aggiungi Commento
  7. Alienware M17x Display Assembly Replacement: passo 7, immagine 1 di 2 Alienware M17x Display Assembly Replacement: passo 7, immagine 2 di 2
    • Use the plastic opening tool to disconnect the screen from the top mount.
    Chiedi a FixBot
    Aggiungi Commento
  8. Alienware M17x Display Assembly Replacement: passo 8, immagine 1 di 1
    • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
    Chiedi a FixBot
    Aggiungi Commento
  9. Alienware M17x Display Assembly Replacement: passo 9, immagine 1 di 1
    • Tilt the screen forward to expose the connecting wires.
    • Disconnect said wires to then lift the display assembly out of the frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 35
Tutti i Tempi: 1,010
