Salta al contenuto principale
Alienware M14xR2 RAM Replacement
Cosa ti serve
  1. Alienware M14xR2 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    Chiedi a FixBot
    Aggiungi Commento
  2. Alienware M14xR2 RAM Replacement: passo 2, immagine 1 di 3 Alienware M14xR2 RAM Replacement: passo 2, immagine 2 di 3 Alienware M14xR2 RAM Replacement: passo 2, immagine 3 di 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alienware M14xR2 RAM Replacement: passo 3, immagine 1 di 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alienware M14xR2 RAM Replacement: passo 4, immagine 1 di 3 Alienware M14xR2 RAM Replacement: passo 4, immagine 2 di 3 Alienware M14xR2 RAM Replacement: passo 4, immagine 3 di 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    Chiedi a FixBot
    Aggiungi Commento
  5. Alienware M14xR2 RAM Replacement, Optical Drive: passo 5, immagine 1 di 3 Alienware M14xR2 RAM Replacement, Optical Drive: passo 5, immagine 2 di 3 Alienware M14xR2 RAM Replacement, Optical Drive: passo 5, immagine 3 di 3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  6. Alienware M14xR2 RAM Replacement, RAM: passo 6, immagine 1 di 3 Alienware M14xR2 RAM Replacement, RAM: passo 6, immagine 2 di 3 Alienware M14xR2 RAM Replacement, RAM: passo 6, immagine 3 di 3
    • Unscrew the two 6.35 mm size 1 screws.
    • Lift up and remove the panel covering the RAM sticks.
    Chiedi a FixBot
    Aggiungi Commento
  7. Alienware M14xR2 RAM Replacement: passo 7, immagine 1 di 2 Alienware M14xR2 RAM Replacement: passo 7, immagine 2 di 2
    • Push outward on both prongs that secure the RAM sticks in place.
    • The RAM sticks will rise upward when released from the prongs.
    Chiedi a FixBot
    Aggiungi Commento
  8. Alienware M14xR2 RAM Replacement: passo 8, immagine 1 di 2 Alienware M14xR2 RAM Replacement: passo 8, immagine 2 di 2
    • Grab and pull the RAM sticks up and out of their casing and set them aside.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Eugene Park
Membro da: 09/30/13
195 Reputazione
Una guida realizzata
Cal Poly, Team 13-4, Forte Fall 2013 Membro di Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Membri
6 guide realizzate
3Commenti sulla guida
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - Rispondi Condividi
I meaned r1 model
Yo, man! If my RAM slot is damaged somehow, is there any possibility to change/repair it? It won't detect a RAM card, keeps beeping 4 times at the start.
tasanov - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 9
Ultimi 30 giorni: 32
Tutti i Tempi: 2,715
