Salta al contenuto principale
Alienware M11x Memory Module Replacement
Cosa ti serve
  1. Alienware M11x Memory Module Replacement, Introduction: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    Chiedi a FixBot
    Aggiungi Commento
  2. Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 2, immagine 1 di 1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 3, immagine 1 di 2 Alienware M11x Memory Module Replacement, Removing the Memory Module: passo 3, immagine 2 di 2
    • Remove the memory module from the memory module connector.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alienware M11x Memory Module Replacement, Replacing the Memory Module: passo 4, immagine 1 di 1
    • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch in the NEW memory module with the tab in the memory module connector.
    Chiedi a FixBot
    Aggiungi Commento
  5. Alienware M11x Memory Module Replacement, Installing the Memory Module: passo 5, immagine 1 di 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Altre 2 persone hanno completato questa guida.
darrius
Membro da: 03/26/18
5.213 Reputazione
30 guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
2.003 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 43
Tutti i Tempi: 801
