Salta al contenuto principale
Alcatel OneTouch Evolve Sim Card Replacement
Cosa ti serve
  1. Alcatel OneTouch Evolve Sim Card Replacement, Locate the access tab: passo 1, immagine 1 di 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    Chiedi a FixBot
    Aggiungi Commento
  2. Alcatel OneTouch Evolve Sim Card Replacement, Place the flat head end of the pry tool into the tab: passo 2, immagine 1 di 3 Alcatel OneTouch Evolve Sim Card Replacement, Place the flat head end of the pry tool into the tab: passo 2, immagine 2 di 3 Alcatel OneTouch Evolve Sim Card Replacement, Place the flat head end of the pry tool into the tab: passo 2, immagine 3 di 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alcatel OneTouch Evolve Sim Card Replacement, Identify the Battery: passo 3, immagine 1 di 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alcatel OneTouch Evolve Sim Card Replacement, Removing the battery: passo 4, immagine 1 di 2 Alcatel OneTouch Evolve Sim Card Replacement, Removing the battery: passo 4, immagine 2 di 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    Chiedi a FixBot
    Aggiungi Commento
  5. Alcatel OneTouch Evolve Sim Card Replacement, Locate Screws Holding the Secondary Panel in Place: passo 5, immagine 1 di 1
    • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
    Chiedi a FixBot
    Aggiungi Commento
  6. Alcatel OneTouch Evolve Sim Card Replacement, Remove Screws: passo 6, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Unscrew each screw, counter-clockwise (left), until each one has been removed.
    • If necessary, use tweezers to fully remove the screws from the device.
    • Remove battery before lifting off the panel.
    Chiedi a FixBot
    Aggiungi Commento
  7. Alcatel OneTouch Evolve Sim Card Replacement, Prying the Panel Off: passo 7, immagine 1 di 3 Alcatel OneTouch Evolve Sim Card Replacement, Prying the Panel Off: passo 7, immagine 2 di 3 Alcatel OneTouch Evolve Sim Card Replacement, Prying the Panel Off: passo 7, immagine 3 di 3
    • Access the small pry tool in the tool kit
    • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
    • Rotate the pry tool 90 degrees until part of the panel lifts up
    • All areas need to be fully risen off before the panel can be removed.
    • Do not use the opening tool to pry open the device near the power button or near the volume button.
    Chiedi a FixBot
    Aggiungi Commento
  8. Alcatel OneTouch Evolve Sim Card Replacement, Locate Sim Card: passo 8, immagine 1 di 2 Alcatel OneTouch Evolve Sim Card Replacement, Locate Sim Card: passo 8, immagine 2 di 2
    • The SIM card is located below the battery in an easy to access location.
    • If there is currently no SIM card in the phone, it will be a blank area
    Chiedi a FixBot
    Aggiungi Commento
  9. Alcatel OneTouch Evolve Sim Card Replacement, Remove the SIM Card: passo 9, immagine 1 di 2 Alcatel OneTouch Evolve Sim Card Replacement, Remove the SIM Card: passo 9, immagine 2 di 2
    • The SIM card is encased in a housing unit. In order to remove it, push left as written on the metal housing cover and it will snap loose and be able to be risen.
    • Place finger on metal housing. While applying a downward force, push the finger in the direction towards the edge of the phone. An arrow also indicated this direction
    • This housing case top will be on a hinge system. Put this top in the upper position and remove card with finger tips, or if necessary, tweezers.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
Brendan Egan
Membro da: 10/28/14
2.491 Reputazione
5 guide realizzate
UMass Dartmouth, Team 4-5, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Membri
18 guide realizzate
4Commenti sulla guida
Easy to follow. Great help. Thank you!
cathyf48 - Rispondi Condividi
Which simcard can I use for Alcatel one touch Wi-Fi in kenya?
james wangwa - Rispondi Condividi
Which sim card can I use for Alcatel one touch Wi-Fi in kenya?
Thank you very much. I thought it has an inbuilt SIM at first. Some of this Model have six screw.
JAMES OBIA - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 24
Ultimi 30 giorni: 160
Tutti i Tempi: 59,401
