Salta al contenuto principale
Alcatel OneTouch Evolve Camera Replacement
Cosa ti serve
  1. Alcatel OneTouch Evolve Camera Replacement, Locate the access tab: passo 1, immagine 1 di 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    Chiedi a FixBot
    Aggiungi Commento
  2. Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: passo 2, immagine 1 di 3 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: passo 2, immagine 2 di 3 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: passo 2, immagine 3 di 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alcatel OneTouch Evolve Camera Replacement, Identify the Battery: passo 3, immagine 1 di 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alcatel OneTouch Evolve Camera Replacement, Removing the battery: passo 4, immagine 1 di 2 Alcatel OneTouch Evolve Camera Replacement, Removing the battery: passo 4, immagine 2 di 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    Chiedi a FixBot
    Aggiungi Commento
  5. Alcatel OneTouch Evolve Camera Replacement, Locate Screws Holding the Secondary Panel in Place: passo 5, immagine 1 di 1
    • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
    Chiedi a FixBot
    Aggiungi Commento
  6. Alcatel OneTouch Evolve Camera Replacement, Remove Screws: passo 6, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Unscrew each screw, counter-clockwise (left), until each one has been removed.
    • If necessary, use tweezers to fully remove the screws from the device.
    • Remove battery before lifting off the panel.
    Chiedi a FixBot
    Aggiungi Commento
  7. Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: passo 7, immagine 1 di 3 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: passo 7, immagine 2 di 3 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: passo 7, immagine 3 di 3
    • Access the small pry tool in the tool kit
    • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
    • Rotate the pry tool 90 degrees until part of the panel lifts up
    • All areas need to be fully risen off before the panel can be removed.
    • Do not use the opening tool to pry open the device near the power button or near the volume button.
    Chiedi a FixBot
    Aggiungi Commento
  8. Alcatel OneTouch Evolve Camera Replacement, Locate the Camera on the Device: passo 8, immagine 1 di 1
    • See yellow square for the location of the camera on the mother board.
    Chiedi a FixBot
    Aggiungi Commento
  9. Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: passo 9, immagine 1 di 2 Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: passo 9, immagine 2 di 2
    • By gently lifting the bottom rectangular piece of the camera component upwards and away from the device, the connection will come free.
    • Remove the rubber casing from the camera, this piece is simply resting over the camera and can easily be removed.
    Chiedi a FixBot
    Aggiungi Commento
  10. Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: passo 10, immagine 1 di 2 Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: passo 10, immagine 2 di 2
    • Place your plastic opening tool underneath the bottom of the camera and rotate the tool to lift the camera. This will take a slight amount of force.
    • You will start to see the silver sticky patch between the camera and the mother board - leave this on the mother board.
    • Keep separating the camera from the sticky patch until completely removed.
    • To replace camera, use the yellow lines on the motherboard as your guide.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
UMass Dartmouth, Team 4-5, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Membri
18 guide realizzate
1Commento della guida
Thank you kindly for your time to write the tutorial.
Tina Mccraney - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 30
Tutti i Tempi: 2,044
