Salta al contenuto principale
Akai MPK25 Keys Replacement
Cosa ti serve
    1. Akai MPK25 Keys Replacement, Face Plate: passo 1, immagine 1 di 1
      • Remove all the selector knob covers by pulling them off.
      Chiedi a FixBot
      Aggiungi Commento
    2. Akai MPK25 Keys Replacement: passo 2, immagine 1 di 1
      • Using needle nose pliers, remove the washers from the four corner selector knobs.
      Chiedi a FixBot
      Aggiungi Commento
    3. Akai MPK25 Keys Replacement: passo 3, immagine 1 di 1
      • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
      Chiedi a FixBot
      Aggiungi Commento
    4. Akai MPK25 Keys Replacement: passo 4, immagine 1 di 3 Akai MPK25 Keys Replacement: passo 4, immagine 2 di 3 Akai MPK25 Keys Replacement: passo 4, immagine 3 di 3
      • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
      • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
      Chiedi a FixBot
      Aggiungi Commento
    5. Akai MPK25 Keys Replacement: passo 5, immagine 1 di 3 Akai MPK25 Keys Replacement: passo 5, immagine 2 di 3 Akai MPK25 Keys Replacement: passo 5, immagine 3 di 3
      • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
      • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
      Chiedi a FixBot
      Aggiungi Commento
    1. Akai MPK25 Keys Replacement, Keys: passo 6, immagine 1 di 2 Akai MPK25 Keys Replacement, Keys: passo 6, immagine 2 di 2
      • Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
      Chiedi a FixBot
      Aggiungi Commento
    2. Akai MPK25 Keys Replacement: passo 7, immagine 1 di 1
      • Lift the key from the front of the keyboard towards the back in order to remove it completely.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
Altre 7 persone hanno completato questa guida.
Will Saba
Membro da: 01/11/13
412 Reputazione
2 guide realizzate
Cal Poly, Team 20-6, Maness Winter 2013 Membro di Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 54
Tutti i Tempi: 11,989
