Salta al contenuto principale
AirCard 770S Battery Replacement
Cosa ti serve
    1. AirCard 770S Battery Replacement, Battery: passo 1, immagine 1 di 1
      • Hold the device with an open corner available and facing you.
      Chiedi a FixBot
      Aggiungi Commento
    2. AirCard 770S Battery Replacement: passo 2, immagine 1 di 1
      • Using your finger, pry open any of the four corners of the back of your AirCard 770S, until you see the back case disconnect from the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. AirCard 770S Battery Replacement: passo 3, immagine 1 di 1
      • Lift open the back case and remove it from the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. AirCard 770S Battery Replacement: passo 4, immagine 1 di 1
      • With the bottom of the device (above the charging port) facing you, use your thumb nail to lift up the battery.
      Chiedi a FixBot
      Aggiungi Commento
    5. AirCard 770S Battery Replacement: passo 5, immagine 1 di 1
      • Once the battery is lifted up, use the rest of your hand to remove the battery out from the device.
      • To put the battery back in to the device, make sure to align the "gold stripes" on the side of the battery to where they correspond in the base of the device, and align the backing to reassemble to device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Marist, Team S1-G2, Chaterdon Fall 2018 Membro di Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 45
Tutti i Tempi: 1,625
