Salta al contenuto principale
Afterglow Wireless PS3 Controller Joystick Replacement
Cosa ti serve
  1. Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: passo 1, immagine 1 di 2 Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: passo 1, immagine 2 di 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Chiedi a FixBot
    Aggiungi Commento
  2. Afterglow Wireless PS3 Controller Joystick  Replacement, Joystick: passo 2, immagine 1 di 1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Chiedi a FixBot
    Aggiungi Commento
  3. Afterglow Wireless PS3 Controller Joystick  Replacement: passo 3, immagine 1 di 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. Afterglow Wireless PS3 Controller Joystick  Replacement: passo 4, immagine 1 di 2 Afterglow Wireless PS3 Controller Joystick  Replacement: passo 4, immagine 2 di 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Afterglow Wireless PS3 Controller Joystick  Replacement: passo 5, immagine 1 di 3 Afterglow Wireless PS3 Controller Joystick  Replacement: passo 5, immagine 2 di 3 Afterglow Wireless PS3 Controller Joystick  Replacement: passo 5, immagine 3 di 3
    • Firmly grip the joystick housing with your forefingers by the yellow squares.
    • Use your other hand to get a grip on the black plastic joystick and pull directly away from the housing.
    • This will take some force to remove.
    • Try not to use the motherboard for leverage because it is delicate.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Aj Coello
Membro da: 02/17/17
1.164 Reputazione
6 guide realizzate
USF Tampa, Team S19-G5, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 41
Ultimi 30 giorni: 155
Tutti i Tempi: 5,562
