Salta al contenuto principale
Acer Chromebook CB3-532-C47C Motherboard Replacement
Cosa ti serve
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: passo 1, immagine 2 di 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: passo 3, immagine 1 di 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: passo 4, immagine 1 di 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: passo 4, immagine 2 di 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: passo 5, immagine 1 di 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: passo 5, immagine 2 di 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: passo 5, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: passo 6, immagine 1 di 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: passo 6, immagine 2 di 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: passo 7, immagine 1 di 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: passo 7, immagine 2 di 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: passo 7, immagine 3 di 3
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 8, immagine 1 di 3 Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 8, immagine 2 di 3 Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 8, immagine 3 di 3
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: passo 9, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: passo 10, immagine 1 di 1
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
Conclusione
Sadie Brown
Membro da: 10/25/21
967 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 622
