Salta al contenuto principale
ASUS X550LB-DS71 Display Panel Replacement
Cosa ti serve
    1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: passo 1, immagine 1 di 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: passo 1, immagine 2 di 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: passo 1, immagine 3 di 3
      • Flip open the laptop with the screen facing towards you.
      • Using the plastic opening tool, remove the square tape from the marked locations.
      • Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
      Chiedi a FixBot
      Aggiungi Commento
    2. ASUS X550LB-DS71 Display Panel Replacement: passo 2, immagine 1 di 2 ASUS X550LB-DS71 Display Panel Replacement: passo 2, immagine 2 di 2
      • Using the plastic opening tool, open the front cover of the laptop.
      • It is recommended that you start from a corner and run the tool along the edge of the cover.
      • Be careful not to bend or crack the cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. ASUS X550LB-DS71 Display Panel Replacement: passo 3, immagine 1 di 3 ASUS X550LB-DS71 Display Panel Replacement: passo 3, immagine 2 di 3 ASUS X550LB-DS71 Display Panel Replacement: passo 3, immagine 3 di 3
      • Peel off the tape located on the left and right side of the display monitor.
      • Use the Phillips #0 screwdriver to remove the screws at the marked locations in each corner of the display.
      Chiedi a FixBot
      Aggiungi Commento
    4. ASUS X550LB-DS71 Display Panel Replacement: passo 4, immagine 1 di 3 ASUS X550LB-DS71 Display Panel Replacement: passo 4, immagine 2 di 3 ASUS X550LB-DS71 Display Panel Replacement: passo 4, immagine 3 di 3
      • Place the display monitor face down to expose the ribbon connector.
      • Remove the ribbon connector to separate the display monitor from the rest of the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S16-G1, Eyestone Fall 2017 Membro di USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 20
Ultimi 30 giorni: 45
Tutti i Tempi: 1,443
