Salta al contenuto principale
ASUS X502CA Fan Replacement
Cosa ti serve
  1. ASUS X502CA Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove:
    • Eight 9 mm screws.
    • Four 5 mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. ASUS X502CA Fan Replacement: passo 2, immagine 1 di 1
    • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. ASUS X502CA Fan Replacement: passo 3, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  4. ASUS X502CA Fan Replacement: passo 4, immagine 1 di 1
    • Remove the keyboard cover panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. ASUS X502CA Fan Replacement: passo 5, immagine 1 di 1
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • If these are not unplugged, the motherboard may shock you.
    Chiedi a FixBot
    Aggiungi Commento
  6. ASUS X502CA Fan Replacement: passo 6, immagine 1 di 1
    • Disconnect the remaining connectors using tweezers or your finger nails.
    Chiedi a FixBot
    Aggiungi Commento
  7. ASUS X502CA Fan Replacement: passo 7, immagine 1 di 1
    • Remove the six 5 mm screws using the Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  8. ASUS X502CA Fan Replacement: passo 8, immagine 1 di 1
    • Flip the motherboard over and away from the screen.
    Chiedi a FixBot
    Aggiungi Commento
  9. ASUS X502CA Fan Replacement: passo 9, immagine 1 di 1
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  10. ASUS X502CA Fan Replacement: passo 10, immagine 1 di 1
    • Unplug the fan's power connector using tweezers or your fingernails.
    Chiedi a FixBot
    Aggiungi Commento
  11. ASUS X502CA Fan Replacement: passo 11, immagine 1 di 1
    • Peel off the marked strip using your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  12. ASUS X502CA Fan Replacement: passo 12, immagine 1 di 1
    • Lift the fan up and away from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Clemson, Team 14-1, Shirley Winter 2015 Membro di Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Membri
5 guide realizzate
2Commenti sulla guida
Great tutorial.
Arthur Rumrill - Rispondi Condividi
Thanks Bro! :)
Crispino A Meola - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 38
Tutti i Tempi: 8,224
