Salta al contenuto principale
ASUS UX50V-RX05 Motherboard Replacement
Cosa ti serve
  1. ASUS UX50V-RX05 Motherboard Replacement, Keyboard: passo 1, immagine 1 di 3 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: passo 1, immagine 2 di 3 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  2. ASUS UX50V-RX05 Motherboard Replacement: passo 2, immagine 1 di 2 ASUS UX50V-RX05 Motherboard Replacement: passo 2, immagine 2 di 2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    Chiedi a FixBot
    Aggiungi Commento
  3. ASUS UX50V-RX05 Motherboard Replacement: passo 3, immagine 1 di 2 ASUS UX50V-RX05 Motherboard Replacement: passo 3, immagine 2 di 2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. ASUS UX50V-RX05 Motherboard Replacement, Case Removal: passo 4, immagine 1 di 3 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: passo 4, immagine 2 di 3 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: passo 4, immagine 3 di 3
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
    Chiedi a FixBot
    Aggiungi Commento
  5. ASUS UX50V-RX05 Motherboard Replacement: passo 5, immagine 1 di 2 ASUS UX50V-RX05 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
    Chiedi a FixBot
    Aggiungi Commento
  6. ASUS UX50V-RX05 Motherboard Replacement: passo 6, immagine 1 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 6, immagine 2 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 6, immagine 3 di 3
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
    Chiedi a FixBot
    Aggiungi Commento
  7. ASUS UX50V-RX05 Motherboard Replacement: passo 7, immagine 1 di 1
    • Carefully lift and remove the plastic cover to avoid damaging anything.
    Chiedi a FixBot
    Aggiungi Commento
  8. ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: passo 8, immagine 1 di 2 ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: passo 8, immagine 2 di 2
    • Remove the four 5 mm J0 screws surrounding the Optical Drive.
    • Remove the optical drive by pulling it out and away from the connector.
    Chiedi a FixBot
    Aggiungi Commento
  9. ASUS UX50V-RX05 Motherboard Replacement, Motherboard: passo 9, immagine 1 di 3 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: passo 9, immagine 2 di 3 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: passo 9, immagine 3 di 3
    • Use the Plastic Opening Tool to unplug the blue cord on the Motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  10. ASUS UX50V-RX05 Motherboard Replacement: passo 10, immagine 1 di 2 ASUS UX50V-RX05 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the five 4 mm Phillips head 5 mm long screws that have white arrows pointing to them with the screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  11. ASUS UX50V-RX05 Motherboard Replacement: passo 11, immagine 1 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 11, immagine 2 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 11, immagine 3 di 3
    • Lift the Motherboard with your fingers by reaching underneath the Motherboard and prying.
    Chiedi a FixBot
    Aggiungi Commento
  12. ASUS UX50V-RX05 Motherboard Replacement: passo 12, immagine 1 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 12, immagine 2 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 12, immagine 3 di 3
    • Remove the two 4 mm Phillips head 5 mm long screws from the fan using the screwdriver.
    • Using the Spudger, carefully remove the white connector and lift the fan out of the casing.
    Chiedi a FixBot
    Aggiungi Commento
  13. ASUS UX50V-RX05 Motherboard Replacement: passo 13, immagine 1 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 13, immagine 2 di 3 ASUS UX50V-RX05 Motherboard Replacement: passo 13, immagine 3 di 3
    • Slowly lift the motherboard up towards you being careful as to not rip any cords out of the bottom.
    • Using the Spudger, remove the connector towards the bottom of the motherboard.
    • Remove the motherboard from the casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
James
Membro da: 02/14/17
663 Reputazione
6 guide realizzate
USF Tampa, Team 20-2, Remmell Spring 2017 Membro di USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Membri
6 guide realizzate
1Commento della guida
From your knowledge is that mother board from the asus ux50v upgrade-able? is the processor integrated into the board?
A Snow - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 26
Tutti i Tempi: 919
