Salta al contenuto principale
ASUS UX50V-RX05 Keyboard Replacement
Cosa ti serve
  1. ASUS UX50V-RX05 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 ASUS UX50V-RX05 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 ASUS UX50V-RX05 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  2. ASUS UX50V-RX05 Keyboard Replacement: passo 2, immagine 1 di 2 ASUS UX50V-RX05 Keyboard Replacement: passo 2, immagine 2 di 2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    Chiedi a FixBot
    Aggiungi Commento
  3. ASUS UX50V-RX05 Keyboard Replacement: passo 3, immagine 1 di 2 ASUS UX50V-RX05 Keyboard Replacement: passo 3, immagine 2 di 2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
James
Membro da: 02/14/17
663 Reputazione
6 guide realizzate
USF Tampa, Team 20-2, Remmell Spring 2017 Membro di USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 32
Tutti i Tempi: 672
