Salta al contenuto principale
ASUS ROG Strix GL503VD-DB71 Battery Replacement
Cosa ti serve
  1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: passo 1, immagine 1 di 2 ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Start with flipping the laptop over so that the bottom side is facing up.
  2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 2, immagine 1 di 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 2, immagine 2 di 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the screw for the small panel with a Phillips #1 screwdriver.
    • Use your plastic opening tool to lift up the cover to remove it.
    • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
  3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 3, immagine 1 di 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 3, immagine 2 di 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 3, immagine 3 di 3
    • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove the back cover exposing the battery.
  4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 4, immagine 1 di 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 4, immagine 2 di 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: passo 4, immagine 3 di 3
    • Remove the single screw securing the battery with a Phillips #1 screwdriver.
    • Gently pull the battery cable from its connector on the motherboard.
    • Lift up on the battery to remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,111
