Salta al contenuto principale
ASUS ROG Spatha X Switch Replacement
Cosa ti serve
  1. ASUS ROG Spatha X Switch Replacement, Mouse Cover: passo 1, immagine 1 di 3 ASUS ROG Spatha X Switch Replacement, Mouse Cover: passo 1, immagine 2 di 3 ASUS ROG Spatha X Switch Replacement, Mouse Cover: passo 1, immagine 3 di 3
    • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
    • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
    • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
  2. ASUS ROG Spatha X Switch Replacement: passo 2, immagine 1 di 2 ASUS ROG Spatha X Switch Replacement: passo 2, immagine 2 di 2
    • Lift the upper mouse cover up and off.
  3. ASUS ROG Spatha X Switch Replacement, Switch: passo 3, immagine 1 di 3 ASUS ROG Spatha X Switch Replacement, Switch: passo 3, immagine 2 di 3 ASUS ROG Spatha X Switch Replacement, Switch: passo 3, immagine 3 di 3
    • Remove the switch(es) you'd like to swap out by gently grabbing them on either side and pulling straight up.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
cgrabowski1
Membro da: 03/21/25
671 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 37
Tutti i Tempi: 230
