Salta al contenuto principale
ASUS Eee PC 1018P Fan Replacement
Cosa ti serve
  1. ASUS Eee PC 1018P Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
    Chiedi a FixBot
    Aggiungi Commento
  2. ASUS Eee PC 1018P Fan Replacement: passo 2, immagine 1 di 2 ASUS Eee PC 1018P Fan Replacement: passo 2, immagine 2 di 2
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  3. ASUS Eee PC 1018P Fan Replacement: passo 3, immagine 1 di 3 ASUS Eee PC 1018P Fan Replacement: passo 3, immagine 2 di 3 ASUS Eee PC 1018P Fan Replacement: passo 3, immagine 3 di 3
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
    Chiedi a FixBot
    Aggiungi Commento
  4. ASUS Eee PC 1018P Fan Replacement, Keyboard: passo 4, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Remove the screws securing the bottom case to the keyboard.
    • Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
    • Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
    • With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
    Chiedi a FixBot
    Aggiungi Commento
  5. ASUS Eee PC 1018P Fan Replacement: passo 5, immagine 1 di 2 ASUS Eee PC 1018P Fan Replacement: passo 5, immagine 2 di 2
    • Pry the cover free from the chasis by inserting the plastic opening tool between the keyboard and the lower body of the Asus Eee PC 1018P.
    • Prying a keyboard from a laptop requires a lot of force, but the keyboard also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    Chiedi a FixBot
    Aggiungi Commento
  6. ASUS Eee PC 1018P Fan Replacement: passo 6, immagine 1 di 1
    • Lift the outside edge of the keyboard upward and inward towards the screen. (See warning below.)
    • Take care not to lift the keyboard too high from the motherboard, as this may sever the ribbon cables that are still attached.
    Chiedi a FixBot
    Aggiungi Commento
  7. ASUS Eee PC 1018P Fan Replacement: passo 7, immagine 1 di 3 ASUS Eee PC 1018P Fan Replacement: passo 7, immagine 2 di 3 ASUS Eee PC 1018P Fan Replacement: passo 7, immagine 3 di 3
    • Remove the black ribbon cable from the motherboard.
    • Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
    • Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
    • Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
    Chiedi a FixBot
    Aggiungi Commento
  8. ASUS Eee PC 1018P Fan Replacement: passo 8, immagine 1 di 3 ASUS Eee PC 1018P Fan Replacement: passo 8, immagine 2 di 3 ASUS Eee PC 1018P Fan Replacement: passo 8, immagine 3 di 3
    • Remove the white ribbon cable from the motherboard.
    • Insert the plastic opening tool under the small lip of the white ribbon connector, and pry upwards to pop the motherboard connector up.
    • Carefully remove the white ribbon cable by pulling it horizontally towards the touch pad.
    Chiedi a FixBot
    Aggiungi Commento
  9. ASUS Eee PC 1018P Fan Replacement: passo 9, immagine 1 di 1
    • The keyboard is now fully disconnected and can now be removed from the main body of the Asus Eee PC 1018P.
    Chiedi a FixBot
    Aggiungi Commento
  10. ASUS Eee PC 1018P Fan Replacement, Fan: passo 10, immagine 1 di 2 ASUS Eee PC 1018P Fan Replacement, Fan: passo 10, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the two 3.76 mm screws securing the fan/heat sink assembly to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  11. ASUS Eee PC 1018P Fan Replacement: passo 11, immagine 1 di 2 ASUS Eee PC 1018P Fan Replacement: passo 11, immagine 2 di 2
    • An additional 3.76 mm Phillips screw is hidden under the seal that reads, "WARRANTY VOID IF SEAL BROKEN OR REMOVED." Remove this sticker to access the screw.
    • Use a Phillips #0 screwdriver to remove the screw.
    Chiedi a FixBot
    Aggiungi Commento
  12. ASUS Eee PC 1018P Fan Replacement: passo 12, immagine 1 di 1
    • Using the spudger, gently push at the top and bottom ridges of this wire bus to disconnect it from the socket.
    Chiedi a FixBot
    Aggiungi Commento
  13. ASUS Eee PC 1018P Fan Replacement: passo 13, immagine 1 di 1
    • Slide the spudger under the righthand edge of the copper heat sink in order to disconnect it from the thermal pad below.
    Chiedi a FixBot
    Aggiungi Commento
  14. ASUS Eee PC 1018P Fan Replacement: passo 14, immagine 1 di 3 ASUS Eee PC 1018P Fan Replacement: passo 14, immagine 2 di 3 ASUS Eee PC 1018P Fan Replacement: passo 14, immagine 3 di 3
    • Peel the foam adhesive pad off from the top of the copper plate, as well as the tape located beneath that.
    Chiedi a FixBot
    Aggiungi Commento
  15. ASUS Eee PC 1018P Fan Replacement: passo 15, immagine 1 di 2 ASUS Eee PC 1018P Fan Replacement: passo 15, immagine 2 di 2
    • Gently remove the fan.
    Chiedi a FixBot
    Aggiungi Commento
  16. ASUS Eee PC 1018P Fan Replacement: passo 16, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two 2.35 mm screws securing the fan to the copper plate.
    Chiedi a FixBot
    Aggiungi Commento
  17. ASUS Eee PC 1018P Fan Replacement: passo 17, immagine 1 di 3 ASUS Eee PC 1018P Fan Replacement: passo 17, immagine 2 di 3 ASUS Eee PC 1018P Fan Replacement: passo 17, immagine 3 di 3
    • Gripping the fan with one hand and the copper plate with the other, gently pull them apart.
    • The fan is now fully removed.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 8-13, Maness Winter 2012 Membro di Cal Poly, Team 8-13, Maness Winter 2012
CPSU-MANESS-W12S8G13
4 Membri
11 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 35
Tutti i Tempi: 7,032
