Salta al contenuto principale
APS Tech 101629 Internal Drive Component Replacement
Cosa ti serve
    1. APS Tech 101629 Internal Drive Component Replacement, External Casing: passo 1, immagine 1 di 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: passo 1, immagine 2 di 3 APS Tech 101629 Internal Drive Component Replacement, External Casing: passo 1, immagine 3 di 3
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    2. APS Tech 101629 Internal Drive Component Replacement: passo 2, immagine 1 di 2 APS Tech 101629 Internal Drive Component Replacement: passo 2, immagine 2 di 2
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. APS Tech 101629 Internal Drive Component Replacement: passo 3, immagine 1 di 2 APS Tech 101629 Internal Drive Component Replacement: passo 3, immagine 2 di 2
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      Chiedi a FixBot
      Aggiungi Commento
    4. APS Tech 101629 Internal Drive Component Replacement: passo 4, immagine 1 di 1
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. APS Tech 101629 Internal Drive Component Replacement: passo 5, immagine 1 di 2 APS Tech 101629 Internal Drive Component Replacement: passo 5, immagine 2 di 2
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      Chiedi a FixBot
      Aggiungi Commento
    1. APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: passo 6, immagine 1 di 2 APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: passo 6, immagine 2 di 2
      • Flip so device is upside down.
      • Remove 4 screws with Phillips #1 screw driver.
      • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
      Chiedi a FixBot
      Aggiungi Commento
    2. APS Tech 101629 Internal Drive Component Replacement: passo 7, immagine 1 di 2 APS Tech 101629 Internal Drive Component Replacement: passo 7, immagine 2 di 2
      • Slide the internal drive component away from the back of the device.
      • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
      • Audio Connection
      • SCSI ID
      • Terminate On
      • SCSI Connection
      • DC Input (power)
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 24-60, Amido Spring 2011 Membro di Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 29
Tutti i Tempi: 1,525
